will s300 cut vtec
onthagozc
will s300 cut vtec
Post by onthagozc »
i am going to be using a s300 for my turbo setup but my dohc zc is non vtec.
will i be able to cut the vtec settings off, or wll i need to use a non vtec ecu.
You can use a VTEC ECU. In SManager, just disable the VTEC and tune using only the low speed tables.
