Wich map can I use (BOOST)
alexb18c1
Post by alexb18c1 »
Have a gsr built T3/t4 stage V, 370cc, wastegate set at 10.5 psi.
Wich base map can I use as temporary solution until dynotune.
Since you have an s300 go to File, New and create yourown basemap. Then make changes to the injector size and check it with a wideband. I would not boost on this until after it is properly tuned.
Your injectors are going to be too small for a boosted application at 10 plus psi. You will need a minimum of 440s and I would recommend 550s.
