ECU
crx4ever
ECU
Post by crx4ever »
I have just swapped a b18c4 engine into my 91 crx mk2.
I want to install a p72 ecu so that the butterfly valves will also work.
The question is the following:
*I can buy a p72 ecu, but this one is normally for automatic transmission
only. Does it matter if I install this ecu, and what "problems" can i expect?
* Do i need to buy an adaptor because i believe my car is obd0?
I also have a APEXI VAFC II installed.
Thnx in advance
Arjen
Automatic P72s are incomapatible with Hondata. YOu must use either a USDM or JDM manual P72. You will need an adpater harness and you will have to remove the vafc.
crx4ever
Post by crx4ever »
this is the code that is on the side of the ecu:
37820-p72-941
804-100511
It is not compatible
