Need a map for 1000cc injector
high_octane
Post by high_octane »
i need a map to run my 1000cc injector can get it to run uless i put omy stock one on, it on a built b18c1 turbo.
viper066384
1000 cc map
Post by viper066384 »
only running 18 psi right now but will start and runs great on this map
high_octane
thanks man
high_octane
hey i cant open that file says to many table cant open.
Make sure you have the lastest version of SManager.
EGJDM
Post by EGJDM »
Can you give us more info on your set up? What motor? pump gas?....
EGJDM
Post by EGJDM »
Can you give us more info on your set up? What motor? turbo?pump gas?....
viper066384
whats done
b18c1 sleeved bored to a 2.0 cp pistons 9 to 1 compression full race head stock cams pump gas 93 or 94 t70 turbo 3 inch all the way back
albastiki
Post by albastiki »
thanks man.....
albastiki
turbocvcsi
Post by turbocvcsi »
can somone please help me get this map please 404 file not found
