NOT able to get car to respond to changes..
fasterthenU
Post by fasterthenU »
I have a car I am tuning,obd0-obd1 b-16 turbo, I am able to tune the car with 310cc injectors but as soon as I put anything else in 750cc, 1000cc the car does not respond to the changes, you can lean it out richen it up and nothing changes on the A/F, and no its not my wideband, I have tried 4 of them, and I have tried 3 ecu's and 4 sets of injectors..
any help would be, nice thank you..
Are you using a resistor box?
fasterthenU
on the 1000cc injectors I am using one, on the 750cc and 310c I am not using one..
Are you sure you have realtime update checked?
RedR
Post by RedR »
I mention having that problem on another post, i do changes on the fuel maps, save it, upload it and datalog it again and it keeps asking for the same values.
I then downloaded the map from the ecu and confirmed it isnt saving the changes.
Its not a soldering problem as i tested changing the 2step to a different rpm and it works.
Set the revlimit to 2500 rpm and upload the calibratoin. Does it take this new Rev limit?
RedR
Post by RedR »
yes it does accept the new rev limiter
deafy
Post by deafy »
open loop or closed loop?
RedR
Post by RedR »
this was tested on open loop
Large injectors have a lot of dead time at low rpm and low duty cycle. You may have to make changes in huge increments to actually see changes. Try a 50% change (ctrl-J).
RedR
Post by RedR »
ermmmmmm r we talking about my problem at all? lol
