Kpro & speedometer
Jor-El
Kpro & speedometer
Post by Jor-El »
I have a jdm dc5, and I have installed prb krpo ecu.
My question is this: With the kpro installed are the readings on my speedometer and odometer in mph or kph?
If they are in mph, is there any way to convert it to kph?
Also the speed cut is automatically removed with the kpro ecu installed, correct?
The ECU (and therefore KPro) has nothing to do with the speed signal and speedometer, so your speedo will read in kph if it is JDM.
There is no speed limiter on the US ECUs.
Jor-El
Post by Jor-El »
Ah, that's great...thanks for allaying my concerns.
