How to add RPM cells on Table
WickedCivicNY
Post by WickedCivicNY »
This may be a ridiculous question, but how do you expand the RPM range .. For example My table reads.. from 500 RPM to 8950 RPM, How do add additional cells where it could read 500 RPM to 9500 RPM ?
Any help would be appreciated.
If you want to expand the high speed cam rpm index all you have to do is right click on the first column of the 0 rpm row, and select 'Delete RPM Index'. The 0 rpm row is deleted (which is useless anyhow for the high speed cam) and an additional row added to the end of the table. To tweak the last rpm value right click on it and select 'Edit RPM Index'. You could also deleted the 600, 1000, 1500 rpm rows if you wish, and insert values inbetween the rpm rows to give more resolution.
