Wideband on ELD input problem
Gigi
Post by Gigi »
Hello
I Have a Hondata ECU already socketed for S300. I have a boumslang harness. My car is a itr B18C6. For the moment everything stock. I connected for the first time the s300 and everythings seemed to be ok. I can datalog and was able to read the stock narow O2 sensor. (sinusoidal signal)
Now I try to connect a wideband UEGO with a 0-5 output voltage. I connected to the ELD (cut on the boumslang wire on the D10 pin) changed the setting following the Wideband voltage table, disconnect the closed loop but I cannot read anything els than 4.53Volts... Connected and not connected always 4.53 volts. I tryed to connect on the EGRL (D12) but there it's now a fix 11,50 AFR that the s300 read..? Than I wanted to connect to the O2 sensor input (D14) but what a surprise.. no wire comes on the ECU on D14.... :shock: Is the harness the problem??
There is also a problem with the Knock voltage level, with my stock ECU OBD2 I have no error code... (no motor lamp lighting)
Thanks a lot for your help and greetings from Switzerland
Gilbert
Gigi
Post by Gigi »
Sorry I didn't says that the wideband is a AEM Wideband UEGO gauge type.
thanks
DipDip
Post by DipDip »
Hi Gigi,
Send me email
QUICKSILVER RACING
Post by QUICKSILVER RACING »
Maybe your ECU doesn't have ELD input. Some ECUs dont have that.
If your harness doesn't have a wire in D14, you can remove the ELD wire and transfer to d14.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
Is your ELD wire still connected to the ELD as well?
zof484
Post by zof484 »
Hi
I have same kind of "ELD" problem.
My car is EDM Honda Civic Vti B16A2 1999 OBD2B.
Im using P28 ecu with built in obd2b plugs and s300.
I tried to wire plx wideband into the eld wire but then i noticed that i dont have eld at all.
Then i tried to find that C6 wire ( on the edm obd2b harness) so i could
wire the plx into the EGRL... but i dont have that c6 wire either.
So where i supposed to wire my wideband..?
Thanks for help and sorry my bad english...
Gigi
Post by Gigi »
Oh I think I figured out...
I thought that the pin numbers (D10)were the numbers on the ECU. But that's not the same numbers who are described on the Hondata help!
Hondata: do think I could have broken something in the ECU connecting the d22 wich is the TPS ground with 3.5 volts??
Thanks, I try connecting the right wire tomorow!
