Need base map help
REDRAGN53
Need base map help
Post by REDRAGN53 »
I just recieved my JRSC with the Hondata & high boost kit. I will be running max boost 11-12psi on my B18C with 440 injectors, 9.0:1 JE pistons, ported polished head, stock bore, stock cams, intake, header, open 2.5" exhaust.
I need to know the best base map to begin my dyno tune....i will trailer the car there.
...are the RC440 injectors for my 1995 GSR 12ohm or regular...i have a stock setup with no resistor boxes
You will have to measure the resistance of the injectors using a multimeter.
REDRAGN53
Post by REDRAGN53 »
Would I just use the corresponding B18C JRSC 440 injector base map?
