JDM DC5 calibration - PRC ECU
garz
Post by garz »
Can someone let me know which is the best base map for a JDM integra DC5 - running with the original PRC ECU that has been K-Pro'd
engine has CAI and Sports header plus hodata heatsheild gasket
Must be plenty out there
garz
Post by garz »
anyone ??
the car is a 2004 if that helps
Have you tried the one for ITR cams?
garz
Post by garz »
thanks Spunkster - i take it you mean the one for the K20A2 fitted with the ITR cams
i thought the compression ratio was a bit higher in the K20A 11.5 in the A vs 11.0 in teh A2 (i thought), inlet manifold a bit different too - as well as the cams.
any idea how much the above will matterif at all ?
thanks again for the response
garz
Post by garz »
just Picked up the latest Hondata Kmanager update and it has a Cal for the DC5 with CAI and Header - nice
