Downloading Maps (ECU)
Fire_2
Post by Fire_2 »
I know the rev limit and fueling and all sorts used to change when downloading a map from the ECU
has this been sorted with new versions of the software?
anything that can be simply changed say injector size or does alot other things get changed/currupt?
many thanx
Fire_2
Post by Fire_2 »
the dam tuner wont send me the map, and i would like to adjust lanchcontrol and reupload :cry:
You'll have to try it. Although it is not recommended it may still work. It is much better with the newer versions of software.
Fire_2
Post by Fire_2 »
so its still 50/50 its gona work will hondata ever fix this? so it works perfect,
