set timing feature not working
turbotypeR
Post by turbotypeR »
i am trying to set my base timing using the set timing feature and it doesn't seem to be working.no matter if i set it at 12 deg or 40 deg,the timing mark does not move.i am using the 1.1.9.0 version and wondered if it could be because the version has a bug or not.i wasn't wanting to change to the newer version because i heard the boost control feature had some issues and my boost control seams to be working fine .please help!
92 civic Si
best et:9.43best mph:164
turbotypeR
installed the newer version and it works
92 civic Si
Importbanger_001
Post by Importbanger_001 »
Can someone describe how this set timing feature works?
I've searched in the Help file but it doesn't have a description of how it works
It is in the help file, under 'Commands->Set Ignition Timing', or you can search for 'Ignition Timing'.
Importbanger_001
Thanks guys !
