Getting Hondata to work with innovative LC-1
zerospeed
Post by zerospeed »
I am trying to get my Innovative LC-1 to work with hondata. I have butt connected the Aux wire that comes from the LC-1 to the ELD on my P28 Ecu. So the Aux is connected to the ELD wire going to the ECU.
I am trying to figure out how to get hondata to read the wideband signal from the LC-1. I have edited the Lamba table with what is shown on the configurations in the LC-1 (volts and AFR).
I am not sure what to do now? The hondalogger shows a lamba of 0.68 and the LC-1 shows 1.05
I need help in getting the hondata to show the correct lamba so that I don't have to have two laptops in my running at the same time.
Thanks :shock:
It should be somewhat similar to the following:
http://www.hondata.com/techplxwiring.html
zerospeed
Post by zerospeed »
Thanks I'll try that.
laziebun
Post by laziebun »
wondering if you got the lc-1 to work im trying to do the same
zerospeed
Post by zerospeed »
I'm still not able to get the values to match up. I have a P28 so it might not work with the ELD plug so I might have to just do it the other way with only open loop
