Another AEM UEGO question
Phantomhatch
Post by Phantomhatch »
Ive seen some info on the AEM uego wideband but need some input if yea ll dont mind.
-- OK i see people using the ELD as the input and or the o2 input. my question is If i were to use the wideband on the 02 input would have still have to set the vaules for the wideband? if not would the wideband still beable to function as a narrowband sensor like the stock 02?
--Also if i hook it up with the eld do i have to disable it and what values would be used considering AEM uses 32 incramental values for their voltage output ? and the 2300 has 12 boxes for the values.
The AEM cannot be used like the PLX. THe aEM has only one output that you can use. so you have to eather use it as a wideband or as a narrow band, you canot use it as both like the PLX can. THis is why we recommend using the PLX.
