AFR
zach_04lx
AFR
Post by zach_04lx »
Hello,
I currently have an AEM A/F Ratio gauge installed on my K20. However, I'm throwing a CEL because the stock primary O2 isn't hooked up to the K-pro. Is there a way that I can hook up the stock primary O2 into the K-pro (per the wiring schematic) AND keep my AEM gauge?
Basically, I want the K-pro to datalog my AFR (and I want the CEL to go away), but I also would like to keep my AEM AFR gauge.
Thanks preemptively,
Zach
2004 USDM Civic LX coupe
JDM K20a ITR engine (Y2M3 transmission)
Custom intake / exhaust
K-pro PND ECU
Not currently, but this may change soon.
zach_04lx
Post by zach_04lx »
Okay, thanks a bunch! When you say it may change soon, will it be easy to change back? Meaning, if I remove it now to get my CEL to go away, and you come up with a workaround in a few months, will it be easy for me to reinstall my AFR gauge?
Thanks again,
Zach
K-pro PND ECU
