EGR and ELD questions
crxrocks
Post by crxrocks »
I have a S300 installed in a P06 ECU. If I decide to use the ELD input for my PLX wideband do I have to anything physically to the ELD to disable it or is all that is needed is to disable it in SManager.
Secondly, I am considering using the EGRL input for the WB instead of the ELD since my CRX w/ DOHC ZC doesn't have a EGR. Does the P06 contain all of the necessary "guts" to support use of the EGRL input in this manner?
Thanks!
Chris
You need to remove the wire that goes to the eld and then in the calibration disable the eld error.
crxrocks
Post by crxrocks »
Thanks. Do you know of the P06 contains all the hardware required for EGR if I want to use that input instead?
All ecu's should have the input circuitry.
