problems with nitrous on kpro setup
syn11
Post by syn11 »
Hey whats up Ive installed nitrous before on 2 different rsx's with kpro and never had a problem. Now I installed another and this one is kicking my ass cause I installed it correctly and when i hit it nothing happens. I dont know why but when I make the run no nitrous is being sprayed into the car. I even replaced all the wires for new ones and nothing happens still. I installed the relay as per hondata recommends. the activation switch has its own negative, the load goes to the ecu and positive from the switch i have goin to the battery with a fuse....can anybody help me understand this please.....thanks in advance.....
Mods - Type R Cams & I.M & Hondata Gasket, AEM CAI, DCRH, Greddy EVO, ESMM, Hondata K-Pro.
Looks - Skunk2 Coilovers, VIS Carbon Fiber Hood, 8k HID's, 6500k HID's OEM Foglights, 05 Sideskirts, 05 Wing, CWest Front Lip and Rear Valance
TransformedBG
Re: problems with nitrous on kpro setup
Post by TransformedBG »
syn11 wrote:Hey whats up Ive installed nitrous before on 2 different rsx's with kpro and never had a problem. Now I installed another and this one is kicking my ass cause I installed it correctly and when i hit it nothing happens. I dont know why but when I make the run no nitrous is being sprayed into the car. I even replaced all the wires for new ones and nothing happens still. I installed the relay as per hondata recommends. the activation switch has its own negative, the load goes to the ecu and positive from the switch i have goin to the battery with a fuse....can anybody help me understand this please.....thanks in advance.....
what ecu you running?
What ecu do you have the K-Pro in?
syn11
Post by syn11 »
Spunkster wrote:What ecu do you have the K-Pro in?
my bad i have a prb ecu on the car. original ecu sent to hondata.....and i forgot to mention i had done nos on this car also before......
This sounds like a wiring issue with the relay and nitrous solenoid. I would suggest going over it again. You can test your wiring without the ecu.
