datalog not working
turbotypeR
datalog not working
Post by turbotypeR »
i have been having trouble getting my on-board datalog to work.i tried using it with engine parameters and it is hit or miss and usually only gets 2-3 seconds when it does work.so tonight i tried using a manual switch to turn it on and off and it will get a few seconds out of several seconds of the switch being on.for instance, i had the switch on for 20 seconds and got 6 seconds.i do see a red light coming on through the hole in the ecu the whole time the switch is on.what could be causing this?any suggestions?
btw-i read in the troubleshooting post to try and disable it and then delete the recordings and then try it again,but that didn't work
92 civic Si
best et:9.43best mph:164
Do you have the laptop connected while you are using the on-board datalogging? Are you able to datalog normally using regualr datalogging via the laptop wiht on-board dataloggin disabled?
turbotypeR
i had the datalog speed on 30hz and if i recorded 15 seconds,it would only get maybe 5 or 6. i changed it to 10hz and it worked perfect every time.if it was 15 seconds,it recorded 15 seconds.no matter if it was on-board datalogging or from the laptop.
92 civic Si
Can you post the calibration and a datalog downloaded from the s300?
