programming
jdmjake
programming
Post by jdmjake »
i want to program on the fly if i buy the emulator do i need to buy the
standard programmer?
ASE Certified Mitsubishi & Honda technician
pills_PMD
Post by pills_PMD »
you need the pocket programmer . you can't emulate without it as far as i know.
You do not need the Programmer to use the Romulator, however, you will need the Programmer to burn your final chip as the emulator is not to be driven long term on as it only has a battery to keep the program.
jdmjake
Post by jdmjake »
so which is it
can the battrey run off the car 12 v or is it a enternal battery
jdmjake
Post by jdmjake »
what does the emulator look like please mail me a pic
the web site is not clear how it works :?
i want to drive the car and make changes whenever i want
to the ecm on the fly with my lap top :shock: (WHAT DO I NEED) :lol:
jdmjake@msn.com
Mark216t
Post by Mark216t »
The emulator is basically a set of pins on a ribbon cable that goes back to the emulator hardware box - this is connected via a serial port to your laptop.
The ribbon cable is then plugged into the rom socket on the ecu and acts as a rom chip that can be reprogrammed without removing the chip each time.
You can then make changes almost on the fly - I have to turn off the engine before uploading the changes. once you are finished you will need the programmer to programme the burn the changes to a Rom chip for permanent use.
Mark
