doubts about reflash
geil
Post by geil »
Let?s say I send my ecu for a reflash, can I choose the vtec point and the rpm limiter, vtec @5600 rpm and engine limiter @8600 rpms?
Also does the MPG change or remains the same?
Taken straight from the FAQ on the website:
Will this affect the fuel economy?
No. With the extra low end torque you will find can use one gear higher than you normally would. This may improve your economy. If you drive the car harder then fuel economy will suffer. To check your economy measure it over 2-3 consecutive refills - not just one. Fill up at the same pump every time.
