Datalog problem
DipDip
Datalog problem
Post by DipDip »
Hi Doug or Spunkster
- the calibration : attachment
- a datalog of a problem : attachment
- what sort of vehicle you have : ITR DC2 EUDM
- what sort of ECU you are using : Hondata P28 OBDIIa ((0536397) with S300 serial# S300-0079
- a specific description of the problem : see datalog
- Smanager release : 1.2.3.0 (same problem with all release)
Some infomation ?
Best regards
Didier
PS: rename test-1.s3d on test-1.zip and unzip
DipDip
Post by DipDip »
No news ? :roll:
The datalog looks ok - what was the specific problem?
DipDip
Post by DipDip »
See Screen Copy
DipDip
Post by DipDip »
Hondata wrote:The datalog looks ok
:shock: :shock: Nevertheless it is not the case on screenshots
Hondata wrote:what was the specific problem?
It is exactly my question put by this post :wink:
The datalog displays correctly for me. Can you send the datalog uncompressed? Also the datalog date is from October 2006 - is this the correct datalog?
DipDip
Post by DipDip »
Sorry :oops:
Now, this the correct file
The datalog has been opened in an older version of SManager and then re-saved, scrambling most of the values. I'll change SManager to prevent this from occuring.
DipDip
Post by DipDip »
Thank you.
I check by using always the same version.
:wink:
