Post-start idle is Lean..
92hb_hb
Post by 92hb_hb »
Here's my delima.
When I start my car up in the morning, my idle AFR's are normal 13-14's.
But if I shut off my car and go back and start it again, say 10-30 minutes later, the idle AFR's tend to read really lean, around 16-17.5 AFR..
I compared my fuel componsation paramaters on the current skl file to others, and it seems like my Open Loop - Low engine Load corrections %'s are much lower as compared to the other skl files , ie. the stock USp72.skl file.
My current water temp compensation settings are as follows:
-40 | -24 | 7 | 32 | 67 | 106 | 168 | 177 | 302 F
39.8 | 39.8 | 29.7 | 9.4 | 4.7 | 4.7 | 2.3 | 0 | 0 %
The other skl files typically show these numbers:
39.8 | 39.8 | 29.7 | 25 | 20.3 | 15.6 | 7.8 | 0 | 0 %
question is, are my compensation %'s a little low and thus causing me to idle lean when i let the car sit and come back to restart the car.
thanks..
can you post datalogs and calibrations showing the AF?
Gigi
hot start, post start lean problems
Post by Gigi »
Hello,
I have also this problem. Everything is good in the cold start AFR in the 12s/13s then warmed up after hours of tunning, it's in the way around 14.7 wenn cruising but wenn I stop the car (warmed up) then direct after re-start, the AFR at idle goes from 13s to say 16.1.... then wenn I cruise again there is no problem. I try to fix it with playing post start trim since monday but no good results. I m runing open loop.
Here is a datalog from this kind of problem but this datalag is not so bad but I ve recorded more bad lean with the same calibration...
Thanks a lot
