? about Hondata reflash for the S2000
Tony Type S
Post by Tony Type S »
heres the thing im thing about tradin my rsxs for an 06 S2k n i would def want the reflash but idk which 1 i can use....1 is for stock 1 is for toda header...what i was wonderin is the 1 for the toda header says "This reflash is only for use with a Toda header " now would it b ok to also run that reflash w/ an intake n cat back or should i go w/ the 1 for a stock s2k then would it b ok to run thos 3 bolt ons? Lastly does the flash also change w/ the light blinks as u approach redline?
IT is impossible to predict how they will react to different parts, but the Toda should only be used with Toda headers. THe stock one was tested only with the parts listed. More than likely an intake and catback should be fine for the stock reflash.
