S300 QUESTION
HONDARC
S300 QUESTION
Post by HONDARC »
I JUST GOT MY P30 ECU WITH A S300 SETUP. IN RUNNING A 0BD0 TO OBD1 CONVERSION , WHIH A D16Y8 MOTOR.
MY QUESTION IS WHAT DISTRIBUTOR DO I USE, ANY 92 95 SOHC CAM DISTRIBUTOR ? VTEC OR NON VTEC ?
THANKS FOR ANY HELP
I believe this is an OBD2 engine and you can just use the stock distributor for that motor. OBD1 and OBD2 distributors are the same internally, it's just the plug that is different.
HONDARC
Post by HONDARC »
THANKS FOR THE HELP WILL TRY IT
