help picking the right ecm
teggy
Post by teggy »
Ok so I have a few questions. I have 91 integra with a b18a in it and was wondering which hondata to use. I'm planing on turbo and probaly a 100 shot of no2. The next question is should I stay non v-tech or go v-tech? If you say v-tech should i use b18 or b16 head. Any help would be appreciated. Also i am planning on about 15 to 18 psi of boost. Thanks
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100, s200 or s300 depending on what options you want. I would suggest the s300.
As for yoru other questions, those are completely up to you.
