Spoon Venturi Effect & Hondata Gaskets
jime64871
Post by jime64871 »
I just have a plain and simple question. After having the Hondata gasket can you install the venturi gasket and keeping them in @ the same time? or you have to choose one over the other.....This will be going on a B18C R 98 Spec. Just thought i asked....
[b][color=red]STAGE KIDS[/color][/b]
[b][color=orange]Re-Birth '09[/color][/b]
[b][color=gold]Built from passion, not for status[/color][/b]
I see no reason why you wold need to use both. the gains by using the Hondata gasket will probably be better since you are keeping the intake manifold cooler and not just affecting the velocity of the air going into the cylinders.
civicsir+
Post by civicsir+ »
isnt the Venturi plate only for the B16B Civic Type R engines anyway? It will not do any good for the B18CR or other engine.
