Part Numbers for compatible 3-Bar MAP Sensors??
esmith13
Post by esmith13 »
I noticed KManager's pulldown in the MAP Parameters lists all the MAP sensors that have support built in. I was wondering if anyone had any actual part numbers they can share for some of those sensors as well as the wiring harnesses to hook them up with.
Thanks in advance,
Eric
You can get the recommended Motec 3-bar sensor through any Hondata dealer with the plug and everything for $90.
