Where does ECU look when cranking engine?
smracing
Post by smracing »
When cranking engine does the ECU have its own start up map or does it work directly off the main fuel table? I am having an issue with the hot start with bigger injectors.
Should I be using the cranking fuel trim or should I be working with the areas of the map where start up goes?
make changes first to the overall fuel trim, and then start makign changes to your cranking fuel trim. THe last place you want to make changes is the fuel table to fine tune everything.
smracing
Post by smracing »
Everything else is right, thats why I am hesitant to use the overall trim.
When I start the car it cranks on the first turn and then dies and I have to crank and crank and crank to get it to start again. Everything else fine mechanically.
92hb_hb
Post by 92hb_hb »
I'd like to know too.. My car runs real lean for about a minute and has also died out sometimes when I start the eninge after its been off for 10-30 minutes.. my WB shows AFR's in the neighborhood of 17-19..
In the morning when I go start it up, the AFR's are fine and this problem is non existant.. Also, when I"m driving and idling, the AFR's are normal too.. Its just during a warm/hot start will this problem come up.
Any ideas?
Are you both using DSM injectors?
92hb_hb
Post by 92hb_hb »
nope..
GENUINE RC 750 Injectors..
I never had this problem when i was running s200
I woulsd suggest looking at your ECT and IAt compensations...the ECT would be the more important one.
92hb_hb
Post by 92hb_hb »
i will look over the ECT values..
Also..
I"m experiencing another very odd event..
I recentl switched from a chipped p06 to a chipped p28 for my s300 and when I run closed loop with the p28, the engine goes real lean.. I actually have to run it in open loop to get it to idle and read normal AFR's..
The PO6 did not have this problem when switching from open to closed.. Nothing else changed in the settings, other than the ecus..
The only problem could be the ecu then. It may be damaged.
