Map Sensor
thomaskreutzer
Map Sensor
Post by thomaskreutzer »
A long time ago I was trying to eliminate some boost creep and have datalogs from that point in time. I got a new laptop and a new desktop. Now when I am datalogging at idle it displays around 3psi. I am using an AEM 3bar map sensor. I loaded up my old datalogs and had boost cut at 15psi. In the past it showed 15psi, now the very same logs say up to 26 psi. I am not sure how to get the configuration working properly again or if there is a bug I am running into with the new version of Smanager.
thomaskreutzer
Found it
I did not realize PSI was twice listed. One at the top psi and one at the bottom of the list "/psi under sensor setup for MAP. Not sure if it was like that before, but I honestly had not updated versions until I got the new laptop.
psi = shows both pressure and vacuum in psi
"/psi = shows pressure as psi and vacuum in inches Hg
use "/psi
