dirtydseries
Posts: 12 Joined: Wed Feb 28, 2007 9:25 pm
Post
by dirtydseries » Sun Mar 18, 2007 3:11 pm
ok here it goes
started street tuning d16z6 gt30 turbo 750cc injectors 3 bar map
while i datalog i seem to keep getting a map sensor cel code ever other minute..?? i dont know why just when i datalog..
the other is im only running 9psi at the moment..
my injector duty cycle at 9psi at 5500rpm is like 98% and afr is 11.8
why are the injectors maxing out.. they are good for like 600whp..
i used the same injectors and everything on crome pro and it worked fine.. anyone got any ideas?
Posts: 24339 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Mon Mar 19, 2007 1:45 pm
Post your datalog and calibration
Spanky
Posts: 20 Joined: Tue Nov 15, 2005 12:55 pm
Post
by Spanky » Mon Mar 19, 2007 6:02 pm
please post calibration. i would like to compare to my own d series settings. same as yours except i used a to4e 60 trim. and i ran 22 psi
"My other car is a camaro, but today I was in a hurry."
gSIr
Posts: 49 Joined: Sun Jun 25, 2006 11:30 am
Post
by gSIr » Tue Mar 20, 2007 6:05 pm
did u make sure u adjusted for your injector size, also what fuel pressure are you running? Posting your calibration will help greatly
scttydb411
Posts: 85 Joined: Sun Jul 23, 2006 11:10 am
Post
by scttydb411 » Tue Mar 20, 2007 8:50 pm
what fuel pump are you using? what fpr are you using? i would suspect your issue is pressure/flow.
HONDATA DEALER/TUNING IN ATLANTA!!
DIGITALBOXTUNING
678-614-3596
dirtydseries
Post
by dirtydseries » Mon Mar 26, 2007 12:46 pm
i fixed it it waS MY MAP sensor settings i changed from msd 3 bar to motec and boom everyhting went rich as hell.. adjusted it now at 9psi im at 52% duty
dirtydseries
Post
by dirtydseries » Mon Mar 26, 2007 12:47 pm
scttydb411 wrote: what fuel pump are you using? what fpr are you using? i would suspect your issue is pressure/flow.
walbro255 and stock fpr readiong 48psi fuel pressure drops to about 43 in boost imma get a aftermarketand bump it up a few psi like to 50
QUICKSILVER RACING
Posts: 310 Joined: Fri Aug 16, 2002 10:45 pm
Post
by QUICKSILVER RACING » Tue Mar 27, 2007 6:46 am
dirtydseries wrote: scttydb411 wrote: what fuel pump are you using? what fpr are you using? i would suspect your issue is pressure/flow.
when in boost your fuel pressure should rise higher than 48 psi. at 45 psi static pressure and 15psi boost then the actual pressure should be around 60psi.
Check your fuel system.
