Question on wiring to a European EP3
sCorpse
Post by sCorpse »
Hi there!
I got myself a used Hondata ECU from a JDM PRD unit from a 2004 EP3 (Civic R).
I drive a European (GB make) 2002 EP3.
Now i want to switch the ECU with the Hondata ECU which i?ll get soon. I?ve read about the wiring to do to get things working and have questions.
I know that i need a broadband lambda because the UK model has only a narrowband lambda built in, so i ordered a BOSCH LSU 4.9.
First question: Is that the correct lambda and will it meet the requirements for the Hondata ECU. Lambdawindow on this lambda is from 0,65V - infinite.
Second question regarding wiring:
The wiring instrucion on hondata.net sais, i have to connect A22 to the A2 connection. Well, A22 is a unused slot in the UK version harness. Do i have to make a new connection from the unused A22 slot to the A2 (which seems to be pretty hard to do with big fingers) or are there other ways to get a switched 12V to the ECU?
If not, could please provide a how to. I don?t have special crimping tools which would make things even harder for me.
Third question: SMOG test! I think i will fail the smog test with unplugged secondary o2 sensor, right? Do i have to find a good ground point and connect it to the E4 slot to keep my sec. o2 sensor up and running?
Lots of questions, I know. :-)
Thanks for your time!
For this type of question, you will need to contact a UK dealer such as CPL racing since they have experience with this type of conversion.
sCorpse
Post by sCorpse »
Unfortunately they wont give me any information becuase i didnt buy the ECU at CPL Racing... :roll:
kistian
Post by kistian »
hi
to your question about this....
you can use A2 or A3 for suply 12v to A22 and for the negative for the wideband lambda you need to use a wired method, not ground, the metter method is using the E4 wire
scheme for not used the secondary lambda:
internal shunts for keep the original harness:
scheme for use the secondary lambda:
this is my information about the adaptation, very very extended and you can do it without modify your harness: http://www.foroctr.com/viewtopic.php?f=16&t=489
this works good on a PRB, I think the PRD is the same scheme as PRB
if the admin of the site wants this in English, I can post it goodly for all you
mivec24
Post by mivec24 »
Can you post in english i am having the same problem.I have an ecu that would work for type s but i have the jdm spec ep3.I am not seeing crank or cam angle what would i need to change for the type s ecu to work on jdm type r
rikitaun
Post by rikitaun »
mivec24 wrote:Can you post in english i am having the same problem.I have an ecu that would work for type s but i have the jdm spec ep3.I am not seeing crank or cam angle what would i need to change for the type s ecu to work on jdm type r
http://www.hondata.com/techk20-ctr-o2wiring.html
