S300 EGT???
GredonRacing
S300 EGT???
Post by GredonRacing »
Can a EGT sensor be connected to S300? Also which one is recommended to use if possible?
Yes. You'll need something with an analog voltage output. You can use the PLX SM-EGT (you only need the box and sensor - the display is optional), and wire the analog output into one of the analog inputs on the ECU. See http://www.plxdevices.com/products_SMEGT.htm
GredonRacing
Thanks alot, also how do you program it to SManger
Go to Help, Contents, then click on the Search tab. Type in Analog input and hit enter. You will see a number of help topics that should clear this up for you.
