Random Question about that D17 and K-pro
TransformedBG
Post by TransformedBG »
Im just curious about one aspect of the tunning on a D17, since it doesnt have I-Vtec and just has vtec will you still have to add in the cam angles to the k-manager? or across the board will it be static ie:10 degrees?
On a side note, wouldn't it be possible to make a sensor (*say with an electro magnet) that could read the cam angles and and adjust the spark and fuel?
Once you switch off VTC then KManager only shows the 0 degree tables for fuel and ignition. You do not need to put anything in the cam angle tables.
TransformedBG
aww that makes since. I was just wondering since yall have the manual cam gear going on.
