Smanager and Win2k
mark3000
Smanager and Win2k
Post by mark3000 »
Hello, I know their is no support for smanager running on Win2k. This being said, I just have a couple general questions.
Has anyone seen this or been able to run this on Win2k?
Will the newest version of smanager just not work?
Do you need an older version of smanager?
Win2k and XP should be pretty similar. I have smanager running on my desktop that has vista. If it runs on vista (which is completly different from xp) I cant figure out why it wont run on win2k.
Is it a .dll conflict?
memory check?
Any info on this would be greatly appreciated. I think even if you can only answer one question for me, that question would be "Has anyone seen this run on Win2k"? Thanks for your time.
The USB drivers have always only worked with XP/Vista.
mark3000
Post by mark3000 »
Hondata wrote:The USB drivers have always only worked with XP/Vista.
Gotcha! So it's never worked with Win2k, thanks, exactly what I wanted to know.
You wouldnt have the driver names off the top of your head, do you?
24cd?
24c2?
24c4?
24c7?
Shmaa
Post by Shmaa »
SManager, has worked with 98, 2K etc. just fine.
They just dont support it.
mark3000
Post by mark3000 »
Shmaa wrote:SManager, has worked with 98, 2K etc. just fine.
Do you know anyone that has it running in win2k? Did they need to do anything different? Is there a trick to it? As soon as I start it up, windows closes it...the exe caused an error.
Shmaa
Post by Shmaa »
I used to use it on Win2k. Nothing different needed to be done, but this was a while ago with previous versions. I cannot say for sure with the newest version.
mark3000
Post by mark3000 »
Any idea where to get the previous versions? Does anyone have an old version they can send me?
