Probem installing KManager Version 1.2.2.4
jerseyjew
Post by jerseyjew »
I just tried up dating my KManager using the update feature that's built in. While installing it My McAfee said that it was infected with the WIN32 virus and that windows couldn't find a file or one was corrupted. Now my Kmanager doesn't work. What's going on?
jerseyjew
Post by jerseyjew »
Well I disabled McAfee while installing it and it seemed to work fine. I now have the new version up and running. I hope it wasn't really a virus though. Still, Any suggestions on what could be the problem?
tantgron
Post by tantgron »
Have the same problem with FreeAntivir, it said that I had a virus each time I started Kmanager.
Recently we have noticed that anti-virus programs are causing problems.
The applications have digital signatures. If they were infected with a virus, the digital signature would be invalid. You can check the digital signature under properties if you are conerned.
jerseyjew
Post by jerseyjew »
ok well it seems to work fine when I disable McAfee, but is there going to be another release that will allow me to run Kmanager without the hassle of disabling my virus software and firewall software.
Check McAfee - there should be a way of disabling virus scanning for KManager.exe
macer
Post by macer »
Hondata wrote:Check McAfee - there should be a way of disabling virus scanning for KManager.exe
I had the same problem,
I went into
On-access scan properties
Exclusions
Added C:\Program Files\KManager read/write included sub folders
Ran the install again & it worked fine.
jerseyjew
Post by jerseyjew »
Im using McAfee Build 7.1.113 and can't find these exclusion options you are talking about! Any suggestions? There are only options to allow programs through the firewall not the virus scan.
Try completely turning off the antivirus software.
jerseyjew
Post by jerseyjew »
I did that and it works. I get random popup messages all the time though warning me of the virus. It's very annoying. Is there going to be a fix in the future? None of the previous versions did it!
macer
Post by macer »
jerseyjew wrote:Im using McAfee Build 7.1.113 and can't find these exclusion options you are talking about! Any suggestions? There are only options to allow programs through the firewall not the virus scan.
Use the help guide, it can be done.
jerseyjew
Post by jerseyjew »
Still no luck with getting around this. It's getting really old closing out my virus software every time I want to run Kmanager. There has to be some sort of way for this to be fixed!
jerseyjew
Post by jerseyjew »
new version fixed this issue! Sweetness!
