i keep on throwing map code after i boost ????@??
dirtydseries
Post by dirtydseries »
i have a gm 3bar map sensor after i boost sometimes the map sensor code comes on its really annoying.. makes the car go into limp i have t utrn thwe key on and off
after i got the car tuned it got worse maybe because of more psi...
everytime i boost after i let off it throws a code
?? wtf ?
dirtydseries
here is my tune
please post a datalog showing the problem
dirtydseries
i didnt datalog.. it was on the dyno..
its not gonna matter.. its just gonna show boost and when i decel it throws the code.. thats it. it reads perfectly in accordance with the dynos sensors ..
Until you provide a datalog showing the problem, it is impossible to speculate what the problem may be.
scttydb411
Post by scttydb411 »
try another known good 3 bar mapsensor. i've seen a run of a few going bad. tune a car and it runs great for a week or two. car starts idling poorly and reading erroroneously. swap a new sensor in and no problems anymore. you might also want to put an inline filter (like the type supplied w/ electronic boost controllers) to keep anything from blowing into the sensor.
HONDATA DEALER/TUNING IN ATLANTA!!
DIGITALBOXTUNING
678-614-3596
jordancivic
Post by jordancivic »
Do you have closed loop setup?
I read somewhere a long time ago, that during a prolonged decel the ecu will switch from open to closed loop, if closed loop is not disabled ( or setup ) this will throw a CEL. This was back in my Uberdata days so i dont know if there is any relevance.
I cant remember where i read this, and i cant be sure that i have given accurate details, maybe someone can agree/disagree.
Just a thought. Good luck.
scttydb411
jordancivic wrote:Do you have closed loop setup?
i used to drive/tune my own car exclusively with closed loop disabled so i could run leaner and increase economy. never had that issue. i'd have to disagree on that account.
DIGITALBOXTUNING
678-614-3596
jordancivic
Yeah, think it was a glitch with the UBer code or something, like i said i didnt know if it would have any relevance here.
Thanks for clearing that up anyway.
