d15z to D15B vtec Swap P08
SLO-FKR
Post by SLO-FKR »
I have a 93 civic DX with the D15 non vtec, I have swapped in a D15B with vtec. It has a P08 ecu, I was needing to know which wires to hook up for the vtec function to work. Maybe a wiring diagram would be nice. Also is this ecu hondata capable?
Thanks.
There is a complete lis of compatible OBD1 ECUs at http://www.hondata.com/ecus.html. The P08 can be used with the s300j. If you download the Smanager software you can look at the the VTEC parameters and see how the alternate VTEC output is used.
