3 step probs
redline32
3 step probs
Post by redline32 »
I got the clutch switch hondata supports, put my control button in but can't get the launch, full-throttle to work after installing re4..I made sure both were elected s200 clutch switch in the rom and I even tried to choose invert plug still don't work...But works fine if I go back to rom editer 3....any suggestions???
When you datalog in RE4 do you see the clutch switch activate in the sensor list?
redline32
Post by redline32 »
good idea I'll have to get back to you
redline32
Post by redline32 »
finally datalog in re4 and the clutch does show it on and off but i have no check engine light when i hit the button,,but when i do hit the button it will only revb to about 2700 rpms with the clutch in or out....
please post the calibration that you have burned to the chip.
redline32
File
Post by redline32 »
Here ya go...
Also tried to invert plug with no success..
Lemme know
I just tested this on the bench and it works perfectly. Make sure you are burning the chip with the changes you have made. The bin you have posted does not have Full Throttle Shift enabled.
redline32
Post by redline32 »
i'll double check..i know on the re4 cal. it is enabled..but it is a good possibility it didn't make it to the bin...thanks
