bigbadboy
Posts: 21 Joined: Wed Apr 04, 2007 11:02 pm
Post
by bigbadboy » Wed Apr 04, 2007 11:20 pm
just got my s300. new to hondata so i have a few questions. i want to run high/ low boost off the AC switch.
wat do i have to do to make it work like that?? thanks
bigbadboy
Post
by bigbadboy » Thu Apr 05, 2007 5:54 pm
any one got any help for me?
Posts: 24338 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Fri Apr 06, 2007 10:03 am
You have to use the Nitrous/AUX parameters for this.
Shmaa
Posts: 58 Joined: Tue Sep 13, 2005 2:34 pm
Post
by Shmaa » Fri Apr 06, 2007 12:36 pm
Spunkster wrote: You have to use the Nitrous/AUX parameters for this.
What?
bigbadboy
Post
by bigbadboy » Fri Apr 06, 2007 9:55 pm
ok so how exactly would that work??
Post
by Spunkster » Mon Apr 09, 2007 9:46 am
Use a dual stage boost controller that has a switch to togle from the 2 settings and use the nitrous/aux controls to setup the conditions and parameters you want for this. Then use the output to trigger the boost controller.
bigbadboy
Post
by bigbadboy » Wed Apr 18, 2007 9:20 pm
but i'm going to be using a apexi boost selenoid
Post
by Spunkster » Thu Apr 19, 2007 9:33 am
If you are using a boost control solenoid, then you just go into the Boost Control parameters and set it up.
bigbadboy
Post
by bigbadboy » Thu Apr 19, 2007 8:26 pm
ok so all i have to do is set the high/low boost to active with the ac switch?? i tried to set the ac switch to turn on and off my dataloging but it didn't work. so i'm thinking there is a little more work involved in making it work properly
Post
by Spunkster » Fri Apr 20, 2007 9:36 am
You have to wire a switch to the input you are using.
bigbadboy
Post
by bigbadboy » Fri Apr 20, 2007 9:33 pm
yeea i want to use the actual switch for the ac.
