Datalogging graph setup
rjmcalister
Post by rjmcalister »
Is it possible to view the cursors x,y coordinates using the S300 datalog graph?
Can you be a little more specific?
rjmcalister
X<Y graphing
While viewing a datalogged graph is it possible to view the cursors X,Y coodinates as you drag it across the graph? I guess the main thing is can the Y axis be scaled, for example the MAP sensor graph shows the range being 0-3 Bar. I would like to be able to place the cursor at 7500 rpm, somewhere above the x axis and be able to see what reading the MAP sensor is showing. Currently I have guess where I am between 0 and 3 Bar.
While draging the line across the graph just look at the sensor list or the display and you can see exactly what the sensors are reading at any point on the graph.
rjmcalister
Datalogging graph
just what I was looking for, thanks
