Boost solenoid mounting location
Praylewd powr
Post by Praylewd powr »
As per my other post, I wanted a followup to this question:
I originally had my solenoid mounted behind the pass headlight but moved it closer to the wastegate to shorten the vacuum lines to lower boost creep. It seemed to help a bit, but was wondering if mounting the solenoid by the distributor was a poor location heat-wise? Everywhere under the hood is hot so I doubt it would pose an issue, but wanted feedback from Hondata so I don't have to replace the solenoid in the future.
Duane
The firewall is usually a good location for the solenoid.
