Under parameters...
DC5RK20A
Under parameters...
Post by DC5RK20A »
While in parameters, under the Knock/TPS tab I can not get the TPS to read while the PC is connected and key positioned to ACC. I was wanting to set the TPS per the help file. I'm not having a problem with TPS that I am aware of, just curious as to why it's unreadable. Any ideas?
Thanks.
The Power of Dreams...
2007 Snisen
What version of software are you using from Help, About? Are the lights on in your cluster?
Key to ACC? Do you mean key to the ON position?
ECU/version/datalog?
