Code 9 on turbo h22a
Hadi
Post by Hadi »
hi
will , after the installation is done , the car the ecu through code 9 , Cyl sensor error as i remember , we tried to get rid of it but it still there, so we moved the ecu and installed it in another h22a engine , it throughs the same could,
so my question is , is my ecu is dameged ?
please need help as soon as possible .
Who socketed the ECU? IF you tried it on another ecu it will probably be a bad ecu.
Hadi
Post by Hadi »
the ecu was done at locash racing .
sorry i didnt mention that the ecu was workin fine, thats before the car got an accident , so we swapped everything to ek9 civic , since then we got code 9. even if we tried the ecu on another h22a , we still got code 9 .
Sounds like the ecu was damaged in the accident.
92hb_hb
Post by 92hb_hb »
I had this exact same problem w/ a chipped p06 that I used for s300.. It worked fine for a couple weeks w/ no problems, but began to throw this code every now and then and eventually most of the time..
Sometimes it would result in the enigne stalling and was more of a nusiance.. I finally got tired of it and swapped it out for a different ECU w/o the problem..
IN the end, I think the ECU went bad some how..
