3 step help!
fu@k_awd
3 step help!
Post by fu@k_awd »
So i have been running a tuned base s200 on my car for a while now and i just got around to installing the 3 step. first i have read both install guides front to back a few times, the push button and clutch switch are installed and hooked up to the hondata box. When i try and set the launch control or any other rpm it never sets. the CEL flashes like it is suppose too and stops when i press the brake but nothing ever sets.
fu@k_awd
Post by fu@k_awd »
the clutch switch and push button are getting power. im just not sure were the brake switch is on my p28 ( i think its d2)
http://www.hondata.com/techwiringgsr.html
What is the serial number of the s200?
fu@k_awd
Post by fu@k_awd »
It is hard to make out those diagrams, they are blurry. The serial # is - 2465
view the full sized images
fu@k_awd
Post by fu@k_awd »
Ok - i was right it is d2. What do i do if the hondata isent seeing the brake switch signal? can i check this through hondalogger if i dont have datalogging?
You cannot check it if you do not have datalogging. I would suggest taking it to a Hondata dealer so they can use their dealer kit to datalog and make sure that the ecu is seeing all the inputs.
fu@k_awd
Post by fu@k_awd »
Ok well how can i check it without datalogging? if the hondata wasent seeing the brake signal whould the CEL still stop blinking when u press the brake?
so did my s200 have 3 step enabled?
You have not purchased the 3-step option.
fu@k_awd
Post by fu@k_awd »
i have purchased it.
just ordered the 3 step upgrade through a hondata dealer and all i got was the 2 cables. what do u suggest.
I suggest contacting your dealer because no 3-step option has been purchased for this s200.
fu@k_awd
Post by fu@k_awd »
Well when i bought it i gave them my serial number. do they activate it or whould they send me a code like datalogging or boost?
Ill contact them.
fu@k_awd
Post by fu@k_awd »
Ok i finally got my code from the dealer. the launch control is working and setting fine.but the FTS is acting like an overall rev limiter. first run on default settings the car hits a rev limiter at 6k.werid. so i change the FTS to 8k, same thing. so iv left it set at 10k.
The clutch switch must be engaged to disable the full throttle shift. You cannot rest your foot on the clutch.
fu@k_awd
Post by fu@k_awd »
both runs my foot was away from the clutch as i rolled into the gas.
