UK Civic Type-R EP3 with JRSC and 650cc RC's + datalog graph
chippyleigh
Post by chippyleigh »
Hi there, I am after a map for the following :-
UK Civic Type-R EP3
JRSC s/c (civic si race model)
650cc RC injectors
Toda Header
Spoon N1 catback
PRB ecu with wideband lambda
97-98 octane fuel
We have tried using K20a2-rsx-650cc-jrsc-10-psi but are getting knock when revs drop down from 7000 rpm.
On the last run datalogging lambda gave 11.5 to 14.70
Any ideas on a better map would be appreciated.
Darren
For a setup like this, you will have to tune it on the dyno.
chippyleigh
Spunkster wrote:For a setup like this, you will have to tune it on the dyno.
I understand this but I wanted another map for this setup until we can get on a dyno, over here in the UK some people are charging over ?400 for a dyno tune (they won't do it by the hour) which is just over $800 so a more suited map to get us by would be appreciated.
I have also noticed that knocks seem to be evident when changing gear, ie when boost drops off that is when knocks are present.
The datalog File :-
chippyleigh
anybody ??
scottishpol
Post by scottishpol »
Where abouts are you in the UK?
I can get you dyno time at a very reasonable price up here in Scotland.
chippyleigh
scottishpol wrote:Where abouts are you in the UK?
Its for a mate and he lives just north of Manchester.
trlaing
Re: UK Civic Type-R EP3 with JRSC and 650cc RC's + datalog g
Post by trlaing »
chippyleigh wrote:Hi there, I am after a map for the following :-
UK Civic Type-R EP3
650cc RC injectors
Toda Header
Spoon N1 catback
97-98 octane fuel
Darren
Hi
Did you ever find a better map for your setup? I have the same JRSC kit with ITG Maxogen air filter, standard exhaust manifold, DC Sports catback. When I received my K-Pro there was a problem with the map so I was told to upload the same one you are using. I haven't driven it yet but it seems to start and rev fine. I have to drive 460 miles to get it mapped so would like a good base map so it survives the journey!
Any help would be much appreciated!
Teamko
Post by Teamko »
send me datalog and current map I can optimizm your tune.
