if i can still use my ECU ??
monty
Post by monty »
i just bought a s200 and i want to make sure it works fine .. how can i do it cuz the guy use it for boost ... can i take out the S200 from the ecu and plug it in me car to see if it works .. when i open it ,it works burn
Has your ecu been socketed for use with a Hondata system? Have you burned a Hondata rom?
monty
Post by monty »
yes it its .. and nope i haven't burned it yet ... when i open the ecu to check i notice some burn spot .. but i haven't try to use the ecu yet cuz he said that hes use bigger injectors .. but i only have stock . some how can i make this work ?
Too many unknowns at this point. I wouls suggest taking this to a Hondata dealer to have them look at it and if they say it works, then have them get you a base map for your setup.
monty
Post by monty »
that sound good . where's the nerest hondata dealer ? im at the valley CA . would you haen to know how much they charge ?
monty
Post by monty »
thanks
