effects of reflash with the greddy turbo kit????
06civicsi
Post by 06civicsi »
i have the reflash and im about to install the greddy turbo kit.
i know that the advancing of the cam angle is what will make us lose power with a turbo.but how much did yall advance the timing?is it enough advancing to cause hp and tq loss?
what should i expect? and is there a way for it to be corrected?
thanks,
brent
Assuming you mean the 06-07 Civic Si reflash, the ignition timing has not been altered. The cam advance changes are not that much - the factory tuning was fairly good.
06civicsi
Post by 06civicsi »
Hondata wrote:Assuming you mean the 06-07 Civic Si reflash, the ignition timing has not been altered. The cam advance changes are not that much - the factory tuning was fairly good.
ok thanks.so its ok to have the reflash and run the greddy turbo kit and not have much power loss?
thanks for responding hondata!!!
