ELD used as WideBand O2 Input. Diable ELD, or not?
mrw
Post by mrw »
Just wondering if you should disable EDL under the misc option on setup, when using the ELD as your wideband O2 input, or should I leave it enabled.
Does this disable the ECU from looking at the ELD signal all together (I should leave it on so it can read my O2). ....or does it tell the ECU to simple not make any adjustments based on the ELD signal, but it still reads in the ELD channel, thus I should check the disable box.
Disabling ELD only disables the error associated with not having an ELD.
