Fan control will this work?
b20luda
Post by b20luda »
Ok i basicly just want to know if this will work the way i want to wire this please help me out here....
Going to wire my radiator fan to the nitrous/aux input/output
arming input set to always on?
output im going to use pin A20 purge control
now do i need to use a relay to ground, i planned on using a switched 12v power source wired directly to fan and the output wired to the ground side of the fan do i need a relay inbetween ecu and fan for ground?
b20luda
Post by b20luda »
also is there a way to run off the wastegate spring only and then have low/high boost switch as well
CivicVTi
Post by CivicVTi »
What exactly do you plan to control with this setup?
b20luda
Post by b20luda »
The radiator Fan...
Your radiator fan should be controlled by the thermo switch in either the radiator or the thermostat housing.
b20luda
Post by b20luda »
i know this, but it would be nice if i wired it up so i can adjust when it comes on....catch my drift...im just wanting to know if the ECU is capable of grounding that thing without a relay??
You should always use a relay when trying to activate solenoids and fans or anything that requires any amount of current.
crucian
Post by crucian »
I think the S300 should come with a fan control option. :wink:
