Important info for those tuned with or using Romeditor 4
ROM Editor 4 tuning software questions and answers.
1. You should frequently check for updates and make sure that you have the latest version of software.
2. Serial datalogging is now possible by anyone as long as you are using version 1.0.7.0 or newer. This also requires that the EEPROM be programmed with the newer version also.
3. In order for 3-step functions to be usable and updatable by the end user, the options must be enabled and the outputs they wish to use must be selected when the EEPROM is burned.
4. A car tuned with Romeditor 4 cannot be datalogged with Hondalogger.
5. You cannot burn an EEPROM with an RE4 file. You must save the file as a BIN which is 32kb in size.
6. If you load a earlier version of a Romeditor 4 BIN, you will have to save it as a RE4 file, then save it as a bin to update it so it can be reburned.
seen4ever
Re: Important info for those tuned with or using Romeditor 4
Post by seen4ever »
Spunkster wrote:6. If you load a earlier version of a Romeditor 4 BIN, you will have to save it as a RE4 file, then save it as a bin to update it so it can be reburned.
ahhhhhhhhhh, I think that explains all of my problems.
thank you sir
2004 Infiniti G35c
1992 Honda Civic CX
2005: 11.2@133 cracked sleeve
2006: more power :)
